For a bit of fun:
A couple of XI-related sockets. What size are they and where are they used?
What Sockets Are These??
Re: What Sockets Are These??
A better view? Hopefully, you can't read the text on the side of the right-hand one!
I've just spent the day installing new rear half shafts and new front hubs. I shall therefore exclude myself from this quiz...........
1 5/16" socket: Original crank shaft damper bolt. I only need this one once for each engine, as I replace the big hex bolt with the compact ARP flanged bolt.
1 7/8" socket: Rear axle hub nut.
Stuff I only use on Spridgets, and the Westfield.
Oh yes, that's the 1 5/16 in your hand.
You win the prize*, Jan!
The rear hub socket is, well, bloody massive!
*Bugger All, sadly.
*Bugger All, sadly.
And my prize is???
I hope not another set of used GAZ or SPAX dampers. or another set of front hub ball bearings...
See above:
*Bugger All, sadly.
But you may feel that Bugger All is prefereble to those items you listed!
*Bugger All, sadly.
