Front wheel bearings
Post by sgrant »
http://www.midgetregister.com/index.php ... &Itemid=66
Anyone taken the plunge? Or should I be the first? My hubs have play and the castellated nut doesn't tighten any more than it is without stopping the hub from spinning....
brian
Re: Front wheel bearings
Post by brian »
That's an excellent article. I've cut'n'pasted it into a Word doc for safe keeping. One of my front bearings is showing signs of being on the turn so it's great to have a suggestion for improvements.
Do you think you'll go for it?
Brian
Post by sgrant »
I think I will. The MOT tester picked up on my wobbly bearings, although he didn't fail me. I've tried nipping them up, as I would with normal car bearings, but they don't nip, as I'm sure you know, so I think that I should try to source the SKF ones and give them a go; like you say, it's such a comprehensive article even I should be able to manage it. I just need to take the plunge in plenty of time before LMC...
brian
Post by brian »
My XI passed its MOT yesterday and they only thing they picked up was a slight wobble on the NSF bearing. Having read that article I now understand why. MOTman reckoned it would be good for another 10-15k so I'll plan to change the bearings at the end of the Summer.
Possibly next weekend then...
Post by sgrant »
Yeah, I can't see it being an issue for the car, only for the MOT. Mine have a very slight wobble on both sides, but I just can't believe that it's really an issue.
Post by sgrant »
Ok, well simplybearings.co.uk are quoting £35 + VAT for each bearing! So £165 for the set then.
If someone else happens to find these cheaper, please let me know. Otherwise, I think I might put up with the wobble for a little longer!
s
Post by sgrant »
http://smithtr6.com/bearings.htm
Now that is what I call a comprehensive article!
Post by sgrant »
Holy
Crap
http://www.british-cars.net/mg-midget-s ... 426924.htm
Don't even go there......
I just don't understand it - how can a bearing on such a popular sports car be so problematic? I'm not really sure what to do now.....Perhaps I put taper bearings on for the MOT and then take them off again :?:
So far so good - very slight play but nothing worrying. If it gets too bad my first call would be to try to source equivalent size taper rollers.
Post by Mknight702 »
sgrant wrote: Anyone taken the plunge? Or should I be the first? My hubs have play and the castellated nut doesn't tighten any more than it is without stopping the hub from spinning....
I had similar trouble with my front hubs. That is until I found out that there is supposed to be a spacer between the bearings so you can't over tighten them. The spacer sits between the inner races so if you do over tighten it still shouldn't stop the wheel turning.
