Re: LED HEADlighting.
Posted: Fri Sep 09, 2016 11:37 pm
I should add that you shouldn't fit LED headlight bulbs without having self-levelling suspension or a headlight wash/wipe system!
I took the time to tack a dust sheet to my gates and adjust the woefully ill-adjusted lamps (the dipped-beam cut-off should fall 3" below the centreline of the lamps at a distance of 25', etc).
Here we see the lights, dipped beam and main beam (engine off):
