The Denso alternator wiki (Part Number DAN968)
Lighting and Electrics Maintenance and Upgrades
Re: The Denso alternator wiki (Part Number DAN968)
I found a link to what looks like the correct THREE pin plug for MY alternator. P IG L or S IG L. The P or S is the voltage sensing pin for the alternator regulator, and is, apparantly, best connected to the battery directly.
https://www.ebay.co.uk/itm/Alternator-D ... Sw3ONZpUfe
With wires pre-crimped: https://www.ebay.co.uk/itm/Alternator-D ... SwkWdZzMAO
Male pins version for whatever reason you might need one! https://www.ebay.co.uk/itm/Sumitomo-TS- ... SwLVZV0ZV2
The Brise website has some excellent information.
https://www.brise.co.uk/images/CKEDIT/Alt-5020.jpg
Plug types: https://www.brise.co.uk/images/D/altern ... 002-02.gif
Finally, to understand the wiring etc...
Look here:
https://www.brise.co.uk/faq.html
To protect your regulator from electrical spikes if the ignition was pulled while the engine was running, you need a ballast resistor to show a load to the alternator.
Lookfor an approved FIA spec switch,
Discussions on how it works here:
https://forum.wscc.co.uk/forum/topic/92 ... ll-switch/
https://www.lotus7.club/forum/techtalk/ ... h-resistor
