Westfield 11 Build Covered in the Yahoo Eleven Group
Posted: Fri Jul 22, 2011 3:27 pm
If you are interested in following my W11 build, it is covered on the Yahoo Westfield_Eleven Group. Lots of pictures under "The Last XI".
If there are any detail photos that you might like, I can always add them to the gallery.
This particular RHD chassis has been equipped with twin brake master cylinders with remote reservoirs, Westfield a bias bar brake pedal, 15" wire wheels (5" wide front, 5.5" wide, center laced in the rear), TranX LSD, double bearing hubs, Peter May axles, modified Maniflow exhaust header, and a very interesting double pass racing radiator that is about 1/3rd the weight of the stock cross flow but 3X the cooling capacity. The engine is a 1380 with 10.6"1 compression, Longman cylinder head, scatter cam, and a 45 DCOE.
The build is about a month and a half along. The rolling chassis came off the work stands last night. Engine installation should be next week. The thing would be finished by now if not for the delays in acquiring the CR T9 with the "Long 1st" gear set, and a globe trotting LSD.
