This engine has been around for a couple of years now and is going to be for sale as a crate engine soon for $10,000. I see that it is only 20" tall, uses a 12-bolt 9" bell housing and makes 160hp. It will be interesting to see if they develop a clutch and adaptor for inline use! I think an XI would look great with exhausts on both sides and a clear bubble over 4 intake trumpets like an old Ferrari. BTW, my A-series is 22.25" from the bottom of the oilpan to the top ot the filler cap in the valve cover, so this engine might very well fit w/o any Fiberglas work.
http://www.motusmotorcycles.com/kmv4.html
Another engine alternative
Re: Another engine alternative
Reading the brief spec. on the engine , cam in valley/chain drive to cam/hydraulic followers/pushrods/two valves it could almost be a
" Fit and Forget " installation the only engine maintenance would appear to be oil/filter changes . However at $10,000 for a crate engine
it would have to come available on the second hand market before I could contemplate it. Interesting ! ! ! Bob Whittaker
Nice! Of course it's not that much different to the Honda V4 used in the Pan European...bigger, but the Honda engine is well proven.
This is the Katech designed V4, and is essentially half a Chevy V8, right down to the port and combustion chamber shapes.
I would not hold my breath on an inline adapter for a Ford T9 or similar 5 speed.
As for the engine hitting the market second hand, remember that it is installed in an expensive motorcycle. I am sure that once Motus sells a few, there should be an engine or so on the market.
