Hi Folks,
Seeing as this information is not readily available on the net in one place, I'll publish it here (so the next person won't have to dismantle a spare engine to check!).
Backplate (not including gearbox housing bolts)
5/16" x 7/8" UNF (7 no) with spring washer - torque around 20 lbf ft
Clutch cover
5/16" x 3/4" UNF (6 no) with spring washer - torque 20 lbf ft
Flywheel
3/8" x 7/8" (6 no) with single compound lock washer - torque 40 lbf ft
Sump bolts
1/4" x 1/2" (14 no) with spring and oval load-spreading flat washers - torque 6 lbf ft
Oil Pick Up pipe bracket bolts
1/4" x 3/8" (2 no) with star washer. Torque around 8 lbf ft
If anyone can list the gearbox mounting bolts, that'll be most helpful!!
Text for the googlebot:
1275 A Series back plate clutch cover flywheel bolts bolt size UNF thread length engine spring washer
1275 A Series Engine Back Plate Clutch Cover Flywheel bolts
Re: 1275 A Series Engine Back Plate Clutch Cover Flywheel bo
For info:
The depth of the bellhousing-to-backplate threads in the block are 26mm (including the backplate itself which is around 8.2mm).
The width of the flange on the bellhousing is 12mm. So a total of 38mm (minus the spring washer). That's pretty much 1 1/2".
So, it looks like 1 1/4" 5/16 UNF is what I need (bottom bolts run through and are nyloc-nutted). Torque assume standard 20 lbf ft.
If anyone can be so kind as to whizz one out of their car to check, I'd be most grateful!!
ETA: On second thoughts, 1 1/2" might be a better choice. The spring washer will stop any bottoming out, and the full depth of the block thread will be used.
Just make sure that you use Grade 8 or better (Aircraft AN) fasteners.
What's wrong with the bolts you took out Jon?
A troop of gorillas with a box of hand grenades came through my garage. And my house.
Not finding the original bolts isn't too much of a drag, though. The backplate, clutch cover etc look great with new fasteners, even though not visible when fitted.
Hopefully help with the sale as soon as I can get it finished and on the market.
Update:
Four of the bellhousing bolts have lost around 1/8" to ensure they do not bottom out in the block. Rest as per above.
Water pump bolts
5/16" UNF x 1 7/8", 2 no, plus plain and spring washers (17 lbf ft)
5/16" UNF x 1 1/4", 2 no, plus plain and spring washers (17 lbf ft)
W11 water pump pulley bolts
1/4" UNF x 3/4", 4 no, plus plain and spring washers (8 lbf ft)
In other news, sump is on. Waterpump and head about to go on. Might get it done before Xmas!
Water pump bolts
