And another at £29950!
Posted: Fri Nov 07, 2014 5:49 pm
by Chris Todd
Re: And another at £29950!
Posted: Fri Nov 07, 2014 6:55 pm
by beng4
Blimey. Will it really make that?
Posted: Fri Nov 07, 2014 8:35 pm
by bobwhittaker
They are better than money in the bank , ! ? ! ? ! ?
Posted: Sat Nov 08, 2014 7:22 am
by M400too
Do they really make this money I think not in fairly standard build
Posted: Sat Nov 08, 2014 6:20 pm
Well, if it had an LSD, race axles, double bearing hubs with rear disc brakes, 3430 spindles with Timken taper bearings, custom double pass radiator with the duct, CR 5 speed, Protec double adjustable dampers with the special springs, "Chronometric" tach, Weber carb on a 6" manifold, proper race cylinder head, roller rockers, and the period correct bits like the side lights, flat tail light lenses, 15" wheels and Dunlop vintage race tires... Maybe...
I figure that they made about $15,000 USD on the build (labor), which is about right if EVERYTHING was properly rebuilt and improved.
The car is nicely turned out, but otherwise looks like a standard build for the most part, with a warmed over 1380. Nice, but what about the wheel spin off of every corner?
I am guessing that the price is about £3000~5000 too high.
But then again, if you want one, a nice fresh new one, NOW, these are the guys you have to deal with.
I only hope that they properly sorted the thing out after they assembled it. Otherwise, it will be back up for sale by next driving season.
I do like the green interior.
Posted: Sun Nov 09, 2014 10:02 am
by beng4
Much too high i think. A reg check says its still a blue austin Healey sports..... So probably no iva and not registered properly, which will limit its appeal at any price.
