Motive Power Pressure Bleeder
Hi All,
Manily for Jan:
The Motive Power pressure bleeder has been mentioned here a few times over the years.
Any idea what the correct cap for the WSC-supplied reservoir is, please? Or, indeed the thread (which I assume is metric given the modern, plastic, reservoir). I can email Motive Power to confirm before pricing up a unit.
Away from the car at the moment..
Re: Motive Power Pressure Bleeder
Gunson ezibleed works well at half the price? Comes with a few caps IIRC....
End of completely unhelpful post! :D
The standard European cap fits the reservoirs that are commonly found on the 11.
I have been using the Motive Power bleeder for years. It is Excellent!
The pressure bleeder allows one person bleeding and flushing. Very easy.
Better than my Vacula vacuum bleeder, but I still use the vacuum unit for some applications.
I ended up buying a similar Sealey model - VS820 for under £60 on Amazon
https://www.sealey.co.uk/brake-clutch-b ... -5l-vs820/
Works well and the supplied cap fits perfectly.
Euan Hoosearmy
Post by Euan Hoosearmy »
Another vote for the Sealey - if your M/C reservoir is old or no longer available, don't pump it up above 10PSI - slows the bleeding process down a bit but saves a poential expensive and messy incident....
Excellent advice!
Post by Morris »
I suffered a few very messy incidences when I used an easy bleed kit that ran off 20 psi tyre pressure and blew off the reservoir cap!
In the end I swapped over all the bleed nipples to Goodridge Speed Bleed nipples (even on the clutch slave cylinder) that work a treat. I can even monitor the reservoir fluid level by removing the pedal box cover and pumping the brake pedal by hand.
Buy Goodridge Speed Bleeder | Demon Tweeks https://share.google/j8GDDe1OlQGtRJRyN
I remember looking at the Speed Bleeders. Great idea, if a little pricey. Wish they were in stainless!
I saw a link on the MIG Welding forum for a pressure bleeder very much like the Sealey. £18.13 delivered. I've ordered one out of interest, to see if the quality is similar. It comes with a few caps etc. The guy on the forum who ordered it was quite impressed with the plastic thickness etc.
https://share.temu.com/Vomipi37WsB
Here’s the original MIG Welding forum post.
https://www.mig-welding.co.uk/forum/thr ... st-2689181
Mine arrived today. I can confirm it’s a bargain. More accessories than my Sealey, robust construction, and will be getting used for a brake fluid change very soon. I like that it included a collection tube and bottle. Better than gash hose and a Branston jar! The linked offering has risen to £33, but just search brake fluid bleeder in Temu for a selection of the same under £20 delivered.
