More bargain body panels for sale
Post by Morris »
Looks like a pretty complete (no scuttle that I can see), but not perfect set of grp panels (Lemans back) on ebay for the XI:
https://www.ebay.co.uk/itm/195166641371 ... %7Ciid%3A1
And a low back clam:
https://www.ebay.co.uk/itm/195166645121 ... %7Ciid%3A1
And a pair of unused front lower wishbones
https://www.ebay.co.uk/itm/195167156812 ... SwEvxit2yD
All from the same seller - have to wonder what happened to the rest of the car...
Morris.
Re: More bargain body panels for sale
Damn, didn’t write fast enough and all my musings disappeared before they could be uploaded!
Here goes again in short form! I tried to bag the bodywork to get some in stock in case we needed to get moulds at a later date, although Ally Mally obv can supply some eleven stuff (are you still here Malcolm?). Failed due technical issues from dodgy hotel internet in Santiago (Chile).
Did bag the lower wishbones, so only need uppers, trailing links/axle bracket, panhard rod and fuel tank and I will run out of excuses why I’m not building!
Thanks to Morris' assistance I’m in contact with a chap down the road who has just started his XI build, so hopefully will be able to get a few measurements for the few bits I’ll need to get fabricated ( my XI racer has non standard tank, rear mounted, and all rose joint suspension so not what you want for road use) and now can’t get from Westfield.
Cheers all
Tim
