70 miles on it!
In the midst of moving house and it's bananas! :D
Daggers, the manifold is straight - all through...
Good man!
Daggers-xi
Post by Daggers-xi »
Jon,
Back in UK now, have spoken to lads at maniflow about a flat midget inlet and they have asked if you have a record of the overall distance between inlet/head face and inlet/carb face.
Thanks
Daggers
Hi Daggers,
Currently away having a brain-change, but will check Sun/Mon as I can when I am plumbing in my catch tank.
The manifold is a little longer than the Sprite version, due to the carb face being "hinged" out to the vertical by the bottom edge, rather than swung in by the top edge. This is important as it ensures clearance from the exhaust manifold for your heatshield!
Job
Hi Daggers,
The answer is 120mm exactly!
Daggers-xi
Thanks for info, been trying to get hold of maniflow without luck, must be busy, might end up visting factory.
All the best
Daggers
Hi Daggers,
Yes, they seem to be very busy. It may be worth a run over to them. I doubt it would take them too long to run up the manifold. If there are more orders to come, they said they would make a jig.
In other news, I have my modifed and baffled rocker cover back from Loaded Gunn. I'll post a (pre-paint) picture later...
Daggers-xi
Jon,
Going over to maniflow on Monday, just finished rebuilding the carb, the inlet is the last engine bit required.
Daggers
Here are the pics as promised!
Post by allymally »
Hey Jon, you must be expecting some pressure then! ;)
